udfGetElmType()
Return the type of the element set.
type = udfGetElmType (udfHd) ;
User Defined Element
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
type (integer)
Type of the element set.
This routine returns the type of the element set. For example,
Integer type ;
type = udfGetElmType( udfHd ) ;
  • This routine expects a valid udfHd.
  • This routine may only be called within a Body Force, Material Model or Component Model user function.
