udfGetElmNQuads()
Return the number of quadrature points of the quadrature rule for the element set.
nQuads = udfGetElmNQuadType( udfHd ) ;
User Defined Element
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
nQuads (integer)
Number of quadrature points of the quadrature rule for the element set.
This routine returns the number of quadrature points of the quadrature rule for the element set. For example,
Integer nQuads ;
nQuads = udfGetElmNQuads( udfHd ) ;
  • This routine expects a valid udfHd.
  • This routine may only be called within a Body Force, Material Model or Component Model user function.
