udfGetEbcQuadId()
Return the quadrature point ID of the quadrature rule for the surface set.
quadId = udfGetEbcQuadId( udfHd ) ;
AcuSolve User-Defined Example Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- QuadId (integer)
- Quadrature ID of the quadrature rule for the surface set.
Integer quadId ;
quadId = udfGetEbcQuadId( udfHd ) ;Errors
- This routine expects a valid udfHd.
- This routine may only be called within an Element Boundary Condition user function.
