udfGetEbcNElems()
Return the number of elements in the boundary element set.
nElems = udfGetEbcNElems( udfHd ) ;
AcuSolve User-Defined Example Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nElems (integer)
- Number of elements in the boundary element set.
Integer nElems ;
nElems = udfGetEbcNElems( udfHd ) ;Errors
- This routine expects a valid udfHd.
- This routine may only be called within an Element Boundary Condition user function.
