TURBULENCE_MODEL_PARAMETERS
Specifies constants and parameters for turbulence models.
AcuSolve Command
TURBULENCE_MODEL_PARAMETERS {parameters...}
Qualifier
This command has no qualifier.
- spalart_allmaras_cb1 (real) >=0 [=0.1355]
- Spalart-Allmaras model constant.
- spalart_allmaras_cb2 (real) >=0 [=0.622]
- spalart_allmaras_sigma (real) >=0 [=0.66666666667]
- spalart_allmaras_cw1 (real) >=0 [=3.23906781678]
- spalart_allmaras_cw2 (real) >=0 [=0.3]
- spalart_allmaras_cw3 (real) >=0 [=2]
- spalart_allmaras_cv1 (real) >=0 [=7.1]
- spalart_allmaras_rotation_curvature (boolean) [=on]
- Turn on/off rotation-curvature correction (SA-RC).
- spalart_allmaras_cr1 (real) >=0 [=1]
- Spalart-Allmaras rotation-curvature correction (SA-RC) constant.
- spalart_allmaras_cr2 (real) >=0 [=12]
- spalart_allmaras_cr3 (real) >=0 [=1]
- spalart_allmaras_qcr (boolean) [=off]
- Turn on/off Spalart-Allmaras Quadratic Constitutive Relation (SA-RC) model.
- spalart_allmaras_qcr_cr1 (real) >=0 [=0.3]
- Spalart-Allmaras Quadratic Constitutive Relation (SA-RC) constant.
- spalart_allmaras_qcr_cr2 (real) >=0 [=2.5]
- Spalart-Allmaras Quadratic Constitutive Relation (SA-QCR) constant.
- spalart_allmaras_des_type (enumerated) [=ddes]
- Spalart-Allmaras Detached Eddy Simulation (SA-DES) model type.
- des97
- Spalart's Detached Eddy Simulation model.
- ddes
- Delayed DES model.
- iddes
- Improved Delayed DES (IDDES) model.
- spalart_allmaras_des_constant (real) >=0 [=0.25]
- SA-DES model constant applicable to des97 and ddes model types.
- spalart_allmaras_iddes_cl >=0 [=3.55] (real)
- SA-IDDES model constant.
- spalart_allmaras_iddes_ct >=0 [=1.63] (real)
- spalart_allmaras_iddes_cw (real) >=0 [=0.15]
- sst_a1 (real) >=0 [=0.31]
- Shear-Stress Transport (SST) model constant.
- sst_betastar (real) >=0 [=0.09]
- SST model constant.
- sst_sigmak1 (real) >=0 [=0.85]
- sst_sigmak2 (real) >=0 [=1]
- sst_sigmao1 (real) >=0 [=0.5]
- sst_sigmao2 (real) >=0 [=0.856]
- sst_beta1 (real) >=0 [=0.075]
- sst_beta2 (real) >=0 [=0.0828]
- sst_gamma1 (real) >=0 [=0.55555555556]
- sst_gamma2 (real) >=0 [=0.44]
- sst_des_constant_1 (real) >=0 [=0.78]
- SST-DES model constant.
- sst_des_constant_2 (real) >=0 [=0.61]
- sst_production_type (enumerated) [=sst_2003]
- SST Production term type.
- sst_2003
- SST model based on Menter et al., 2003.
- sst_rotation_curvature (boolean) [=off]
- Turn on/off rotation curvature correction for SST model.
- sst_des_type (enumerated) [=ddes]
- SST DES model type.
- zonal
- Zonal DES model.
- ddes
- iddes
- sst_wall_function_type (enumerated) [=all_yplus]
- Wall function type.
- all_yplus
- Wall y+ independent wall function.
- k_epsilon_cmu (real) >=0 [=0.09]
- Standard K-Epsilon model constant.
- k_epsilon_ce1 (real) >=0 [=1.44]
- k_epsilon_ce2 (real) >=0 [=1.92]
- k_epsilon_sigmak (real) >=0 [=1]
- k_epsilon_sigmae (real) >=0 [=1.3]
- rng_k_epsilon_cmu (real) >=0 [=0.0845]
- ReNormalization Group (RNG) K-Epsilon model constant.
- rng_k_epsilon_ce1 (real) >=0 [=1.42]
- RNG K-Epsilon model constant.
- rng_k_epsilon_ce2 (real) >=0 [=1.92]
- rng_k_epsilon_sigmak (real) >=0 [=0.7194]
- rng_k_epsilon_sigmae (real) >=0 [=0.7194]
- rng_k_epsilon_eta0 (real) >=0 [=4.38]
- rng_k_epsilon_beta (real) >=0 [=0.012]
- Realizable_k_epsilon_ce1 (real) >=0 [=0.43]
- Realizable K-Epsilon model constant.
- Realizable_k_epsilon_ce2 (real) >=0 [=1.9]
- Realizable_k_epsilon_sigmak (real) >=0 [=1]
- Realizable_k_epsilon_sigmae (real) >=0 [=1.2]
- Realizable_k_epsilon_eta0 (real) >=0 [=5]
- Realizable_k_epsilon_a0 (real) >=0 [=4.04]
- k_epsilon_twolayer_restar (real) >=0 [=200]
- K-Epsilon two-layer wall-function model constant controlling blending layer location.
- k_epsilon_twolayer_redelta (real) >=0 [=20]
- K-Epsilon two-layer wall-function model constant controlling blending thickness.
- k_epsilon_wall_function_type (enumerated) (=two_layer)
- standard
- Standard wall-function with first-layer y+ in the log-layer only.
- two_layer
- Wolfstein two-layer wall-function with all y+ first-layer height.
- k_epsilon_realizability_constraint boolean [=on]
- Turn on/off Durbin's realizability constraint. Corrects the stagnation point anomaly and improves robustness.
- k_omega_alpha (real) >=0 [=0.52]
- Wilcox k-omega model constant.
- k_omega_betao (real) >=0 [=0.0708]
- k_omega_clim (real) >=0 [=0.875]
- k_omega_sigmak (real) >=0 [=0.6]
- k_omega_sigmao (real) >=0 [=0.5]
- k_omega_sigmado (real) >=0 [=0.125]
- k_omega_rotation_curvature (boolean) [=off]
- Turn on/off rotation-curvature correction for Wilcox k-omega model.
- k_omega_des_constant (real) >=0 [=0.61]
- K-omega DES model constants.
- bsl_betastar (real) >=0 [=0.09]
- Menter's baseline (BSL) K-omega model constant.
- bsl_sigmak1 (real) >=0 [=0.5]
- BSL K-omega model constant.
- bsl_sigmak2 (real) >=0 [=1]
- bsl_sigmao1 (real) >=0 [=0.5]
- bsl_sigmao2 (real) >=0 [=0.856]
- bsl_beta1 (real) >=0 [=0.075]
- bsl_beta2 (real) >=0 [=0.0828]
- bsl_gamma1 (real) >=0 [=0.55555555556]
- bsl_gamma2 (real) >=0 [=0.44]
- smagorinsky_constant (real) >=0 [=0.04]
- Smagorinsky constant used in Large Eddy Simulation (LES) model.
- dynamic_subgrid_model_type (enumerated) [=mij]
- Dynamic Subgrid Model type.
- kolmogorov
- Kolmogorov model.
- mij
- Mij model.
- synthetic_turbulence_input_type or synles (enumerated) (=none)
- Large Eddy Simulation (LES) synthetic turbulence inflow type.
- none
- Deactivate synthetic turbulence flow.
- k_omega
- Provide k profiles and omega profiles at synthetic inflow.
- k_epsilon
- Provide k profiles and epsilon profiles at synthetic inflow.
- film_coefficient_yplus (real) > 0 [=100]
- Value of y+ used to evaluate non-dimensional temperature in surface_film_coefficient.
- von_karman_constant (real) >=0 [=0.41]
- Von Karman constant used in logarithmic law describing a turbulent boundary layer's velocity profile.
- intermittency_ctu1 (real) [=100]
- Intermittency equation constant for Gamma transition model.
- intermittency_ctu2 (real) [=1000]
- intermittency_ctu3 (real) [=1]
- intermittency_cpg1 (real) [=14.68]
- intermittency_cpg2 (real) [=-7.34]
- intermittency_cpg3 (real) [=0]
- retheta_critical_type (enumerated) [=default]
- Critical Re-Theta correlation type.
- default
- Default value.
- user_function
- User-defined function.
- retheta_critical_user_function (string) [=]
- Name of the user-defined function. Used when retheta_critical_type = user_function.
- retheta_critical_user_values (array) [={ }]
- Array of values to be passed to the user-defined function. Used with retheta_critical_user_function type.
- retheta_critical_user_strings (array) [={ }]
- Array of strings to be passed to the user-defined function. Used with retheta_critical_user_function type.
- flength_type (enumerated) [=default]
- F-Length correlation type.
- default
- Default value.
- user_function
- flength_user_function (string) [=]
- Name of the user-defined function. Used when flength_type = user_function.
- flength_user_values (array) [={ }]
- Array of values to be passed to the user-defined function. Used with flength_user_function type.
- flength_user_strings (array) [={ }]
- Array of strings to be passed to the user-defined function. Used with flength_user_function type.
k_epsilon_cmu = 0.1
modifies the standard k-epsilon turbulence model constant c from its default value of 0.09 to 0.1.
sst_rotation_curvature = on
turns on rotation-curvature correction for the SST model.
Synthetic_turbulence_input_type = k_omega
This command is only active when large_eddy_simulation or dynamic_model is chosen at the turbulence command and inflow type is set to velocity or atmospheric. If the k_omega option is set, then corresponding turbulent kinetic energy and turbulent eddy frequency profiles (or values) need to be specified at inflow to generate synthetic turbulence. If k-epsilon is chosen, then turbulent kinetic energy and turbulent dissipation rate profiles (or values) are required to be set at inflow.
