setPointSize()
Set the point size used in various actors of scene graph.
Usage
vis.setPointSize( size = None )
size (integer)
The point size which should be set.
Return Value
None
None
This routine sets the point size used in various actors of scene graph to size. For example,
vis.setPointSize( 3 )
