getPrbDesc()
Get the problem description and equations.
Usage
prbData = repAcs.getPrbDesc( )
None
Return Value
prbData (list)
Problem description info which is (mode, flow, temp, rad, spec, nSpecs, turb, mesh, ext).
None
This routine get the problem description and equations. For example,
(mode,flow,temp,rad,spec,nSpecs,turb,mesh,ext) = repAcs.getPrbDesc( )
