Load Export
An external module invoked from MotionView. This module allows you to take loads from an ADAMS run and create a tabular summary file or a Nastran input card for those loads.
- Identifying and summarizing all loads acting on one or multiple bodies for any give time step(s) in a tabular format
- Identifying and transferring all the forces and moments on one component at any given time step(s) to a Nastran input deck that contains GRID, CORD, FORCE, and MOMENT cards.
Metadata File Generation and Format
MotionView supports force requests on body entities. To provide detailed information about the forces acting on a given body entity, MotionView automatically generates a metadata file if there are active force requests on body entities in the active model. For more information, see the Metadata File Generation and Metadata File Format topics.
To run the Load Export utility:
- The Load Export utility is displayed.
