Edit Element Nodes
Associate nodes to a point, line, or surface/solid face; move nodes along a surface; place a node at a point on a surface; remap a list of nodes to a line; or project nodes to an imaginary line passing through two nodes.
From the Elements ribbon, click the arrow next to the Edit tool set name and select Node Edit from the drop-down menu.
The Node Edit panel opens.
For more information on editing element nodes, see the Node Edit Panel topic.
