Detach Elements
Use the Detach tool to detach elements from the surrounding structure. You can detach elements from a portion of your model so that it can be translated or moved, or you can offset the new nodes by a specified value. You can also use this panel to detach and remove elements from your model.
From the Elements ribbon, click the Detach tool.
The Detach panel opens.
For more information on detaching elements, see the Detach Panel topic.
