Complex Results
For detailed information about complex results, refer to Complex Results.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Load a different solver interface in HyperWorks.
Supported solvers in HyperMesh.
Supported solvers in HyperView.
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
Overview of how the HyperView applications interface with the Abaqus solver.
Overview of how the HyperView applications interface with the ADAMS solver.
Overview of how the HyperView applications interface with the ADVC solver.
Overview of how the HyperView applications interface with Animator DB.
Overview of how the HyperView applications interface with the ANSYS solver.
Overview of how the HyperView applications interface with the I-DEAS solver.
Overview of how the HyperView applications interface with the LS-DYNA solver.
Overview of how the HyperView applications interface with the LS-NIKE3D solver.
Overview of how the HyperView applications interface with the MADYMO solver.
Overview of how the HyperView applications interface with the MARC solver.
Overview of how the HyperView applications interface with Moldflow.
Overview of how the HyperView applications interface with the Nastran solver.
HyperView supports Nastran FEMZIP, OP2 and XDB result file formats.
Animation files are loaded using the Load Model panel.
The options on the Contour, Tensor Plot, and Vector Plot panels in HyperView are based on the Nastran and OptiStruct solvers.
In HyperView you can transform stress results to any coordinate system following certain system projection rules. You also can calculate the stress average using various averaging schemes, and have control over which stresses should be averaged.
The Nastran XDB Results Reader can be customized by using the Reader Options dialog in the Load Model panel.
2D element forces and moments are supported as tensors and can be plotted using the Tensor panel in HyperView.
1D element forces and moments are supported as vectors and can be plotted using the Vector panel in HyperView.
Overview of how the HyperView applications interface with the OptiStruct solver.
Overview of the HyperViewnSOFT interface.
Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
Overview of how the HyperView applications interface with the Radioss solver.
AcuSolve results for steady state, transient and moving/deforming mesh analyses can be imported and post-processed using the AcuSolve Reader (*.log) in HyperView.
Load post-processing files using the Load Model panel.
Supported solvers in HyperGraph.
Solvers and translators supported in MotionView.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
ON THIS PAGE
ON THIS PAGE
