Supported Nastran Results in HyperView
HyperView supports Nastran FEMZIP, OP2 and XDB result file formats.
Data types supported from Nastran OP2 files include:
Data Name Result Type Data Type
1D Element (Forces / Moments)1 ELEMENT VECTOR
Acceleration (Translation / Rotation) NODE VECTOR
Applied (Forces / Moments) NODE VECTOR
Contact (Force / Moment / Traction) NODE VECTOR
Displacement NODE VECTOR
Element (Fluxes / Gradients ELEMENT VECTOR
Grid Point Element (Forces / Moments)2 ELEMENT VECTOR
MPC (Forces / Moments) NODE VECTOR
Rotation NODE VECTOR
SPC (Forces / Moment)6 NODE VECTOR
Summed (Forces / Moments) NODE VECTOR
Velocity (Translation / Rotation) NODE VECTOR
2D Element (Forces / Moments)3 ELEMENT TENSOR3-D |TENSOR2-D
Composite (Stress / Strain) ELEMENT TENSOR3-D |TENSOR2-D
Grid Point Stresses NODE TENSOR3-D |TENSOR2-D
Nonlinear Strain ELEMENT TENSOR3-D |TENSOR2-D
C ELEMENT TENSOR3-D |TENSOR2-D
PSD Stress ELEMENT TENSOR3-D |TENSOR2-D
RMS Stress ELEMENT TENSOR3-D |TENSOR2-D
1D Force:
CROD Axial Force
CROD Torque
CBAR Bending Moment (A1 / A2)
CBAR Bending Moment (B1 / B2)
CBAR Shear1
CBAR Shear2
CBAR Axial Force
CBAR Torque
CBEAM Bending Moment (Plane1 A / Plane2 A)
CBEAM Bending Moment (Plane1 B / Plane2 B)
CBEAM Web Shear (Plane1 A / Plane2 A)
CBEAM Web Shear (Plane1 B / Plane2 B)
CBEAM Axial Force (A / B)
CBEAM Total Torque (A / B)
CBEAM Warping Torque (A / B)
CBUSH Force (x / y / z)
CBUSH Moment (x / y / z)
CELAS1 Force
CELAS2 Force
CGAP Normal x
CGAP Shear (v / w / y / z)
CGAP Axial u
CGAP Slip (v / w)
CWELD Bending Moment (Plane1 A / Plane2 A)
CWELD Bending Moment (Plane1 B / Plane2 B)
CWELD Shear (Plane1 / Plane2)
CWELD Axial Force
CWELD Torque
ELEMENT SCALAR
1D Nonlinear Stress:
CBEAM Equivalent Stress at Point (C1 / C2)
CBEAM Equivalent Stress at Point (D1 / D2)
CBEAM Equivalent Stress at Point (E1 / E2)
CBEAM Equivalent Stress at Point (F1 / F2)
CBEAM Long Stress at Point (C1 / C2)
CBEAM Long Stress at Point (D1 / D2)
CBEAM Long Stress at Point (E1 / E2)
CBEAM Long Stress at Point (F1 / F2)
ELEMENT SCALAR
1D Nonlinear Strain
CBEAM Effective Creep Strain at Point (C1 / C2)
CBEAM Effective Creep Strain at Point (D1 / D2)
CBEAM Effective Creep Strain at Point (E1 / E2)
CBEAM Effective Creep Strain at Point (F1 / F2)
CBEAM Effective Plastic Strain at Point (C1 / C2)
CBEAM Effective Plastic Strain at Point (D1 / D2)
CBEAM Effective Plastic Strain at Point (E1 / E2)
CBEAM Effective Plastic Strain at Point (F1 / F2)
CBEAM Total Strain at Point (C1 / C2)
CBEAM Total Strain at Point (D1 / D2)
CBEAM Total Strain at Point (E1 / E2)
CBEAM Total Strain at Point (F1 / F2)
ELEMENT SCALAR
1D Strain
CBAR Axial
CBAR (SA1 / SA2 / SA3 / SA4)
CBAR SA (Maximum / Minimum)
CBAR Safety Margin (Compression / Tension)
CBAR (SB1 / SB2 / SB3 / SB4)
CBAR SB (Maximum / Minimum)
CBEAM Long Strain at Point (C1 / C2)
CBEAM Long Strain at Point (D1 / D2)
CBEAM Long Strain at Point (E1 / E2)
CBEAM Long Strain at Point (F1 / F2)
CBEAM Margin of Safety (Compression1 / Compression2)
CBEAM Margin of Safety (Tension1 / Tension2)
CBEAM Maximum (Strain1 / Strain2)
CBEAM Minimum (Strain1 / Strain2)
CELAS Strain
CROD Axial (Strain / Safety Margin)
CROD Torsional (Strain / Safety Margin)
CWELD Axial Strain
CWELD Max Shear Strain
CWELD Max (Strain A / Strain B)
CWELD Min (Strain A / Strain B)
ELEMENT SCALAR
1D Stress
CBAR Axial
CBAR (SA1 / SA2, SA3, SA4)
CBEAM Maximum (Stress1 / Stress2)
CBEAM Minimum (Stress1 / Stress2)
CELAS Stress
CROD Axial (Stress / Safety Margin)
CROD Torsional (Stress / Safety Margin)
CWELD Axial Stress
CWELD Bearing Stress
CWELD Max Shear Stress
CWELD Max (Stress A / Stress B)
CWELD Min (Stress A / Stress B)
ELEMENT SCALAR
2D Force
Membrane (x / y / xy)
Bending (x / y / xy)
trans_shear (x / y)
ELEMENT SCALAR
CBEAM Forces4
CBEAM Axial Force
CBEAM Bending Moment (Plane1 / Plane2)
CBEAM Total Torque
CBEAM Web Shear (Plane1 / Plane2)
ELEMENT SCALAR
CHBDYG
Applied Load
Forced Convection
Free Convection
Radiation
Total
ELEMENT SCALAR
Contact Pressure NODE SCALAR
Contact Status NODE SCALAR
Contact Stress
Normal Stress
Friction Stress 1
Friction Stress 2
NODE SCALAR
CSHEAR Force
Force (4 to 1 / 2 to 1)
Force (1 to 2 / 3 to 2)
Force (2 to 3 / 4 to 3)
Force (3 to 4 / 1 to 4)
Kick Force on (1 / 2 / 3 / 4)
Shear (12 / 23 / 34 / 41)
ELEMENT SCALAR
CSHEAR Forces4
Corner Forces
Kick Forces
Shear Forces
ELEMENT SCALAR
CSHEAR Strain
Average shear
Maximum shear
Safety margin
ELEMENT SCALAR
CSHEAR Stress
Maximum shear
Average shear
Safety margin
ELEMENT SCALAR
CWELD Force
Axial Force
Torque
ELEMENT SCALAR
CWELD Strain
Axial Strain
Max Shear Strain
Max Strain (A / B)
Min Strain (A / B)
ELEMENT SCALAR
CWELD Stress
Axial Stress
Bearing Stress
Max Shear Stress
Max Stress (A / B)
Min Stress (A / B)
ELEMENT SCALAR
Damping Energy
Damping Energy
% of Total Energy
Energy Density
ELEMENT SCALAR
Direct Grid Point Stresses
Mean Pressure
Normal (x / y / z)
Shearxy
Shearyz
Shearzx
Vonmises
NODE SCALAR
Direct Strain
Firstprincipal
Normal (x / y /z)
Secondprincipal
Shearangle
Shearxy
Shearyz
Shearzx
Thirdprincipal
Vonmises
ELEMENT SCALAR
Direct Stress
Firstprincipal
Normal (x / y / z)
Secondprincipal
Shearangle
Shearxy
Shearyz
Shearzx
Thirdprincipal
Vonmises
ELEMENT SCALAR
Failure Index
For Direct Stress
For Inter Laminar Stress
ELEMENT SCALAR
Grid Temperatures NODE SCALAR
Heat Flow
Applied Load
Convection
Convection Coefficient
Radiation
Total
ELEMENT SCALAR
Inter Laminar Strain
Shear XZ
Shear YZ
ELEMENT SCALAR
Shear XZ
Shear YZ
ELEMENT SCALAR
Kinetic Energy
Kinetic Energy
% of Total Energy
Energy Density
ELEMENT SCALAR
Nonlinear Strain
Creep
Normal (x / y / z)
Plastic
Shearxy
Shearyz
Shearzx
ELEMENT SCALAR
Nonlinear Stress
Equivalent
Normal (x / y / z)
Shearxy
Shearyz
Shearzx
ELEMENT SCALAR
Axisymmetric Strain
Radial
Azimuthal
Axial
Shear Stress
Maximum Principal
Maximum Shear
Octahedral
ELEMENT SCALAR
Axisymmetric Stress
Radial
Azimuthal
Axial
Shear Stress
Maximum Principal
Maximum Shear
Octahedral
ELEMENT SCALAR
Ply Thickness ELEMENT SCALAR
Shell Thickness ELEMENT SCALAR
Strain Energy
Strain Energy
% of total energy
Energy density
ELEMENT SCALAR
Temperature NODE SCALAR
The following table provides details about HyperView support for Nastran.
  1. See Element Forces (Vector Plot) for more details.
  2. Grid Point Element Forces/Moments are read into HV as element results with Corner Data. Corner data values represent the individual nodal grid point forces/moments for the given element.
  3. See Element Forces (Tensor Plot) for more details.
  4. CSHEAR Forces are read into HV as element results with Corner Data. Corner data values represent the following:
    • Corner Forces: N1: Force 4 to 1
    • Corner Forces: N2: Force 1 to 2
    • Corner Forces: N3: Force 2 to 3
    • Corner Forces: N4: Force 3 to 4
    • Shear Forces: N1: Shear 41
    • Shear Forces: N2: Shear 12
    • Shear Forces: N3: Shear 23
    • Shear Forces: N4: Shear 34
    • Kick Forces: N1: Kick 1
    • Kick Forces: N2: Kick 2
    • Kick Forces: N3: Kick 3
    • Kick Forces: N4: Kick 4
  5. CBEAM Forces are read into HV as element results with Corner Data. Corner data values represent the individual nodal grid point forces for the given element.
  6. Result from OGPFB1 (Grid point force) block: Reader creates data type as “SPC Forces”. And this block will have results like SPC,MPC,Applied forces/moments.
    Results from OQG1 (SPC force) block: Reader creates data type as “SPC Force”. And this block will have only SPC force/moment data’s.
Note:
  • HyperView supports composite stress in OP2 result files generated from Nastran 2012.
  • HyperView supports GPFORCE results in OP2 result files for frequency response.
  • HyperView supports OP2 result files generated with the option PARAM, POST, 1.
  • HyperView supports the following data block names for PARAM, POST, -1:
  • OQG1, OUGV1, OES1, OEF1, OSTR1, ONRGY1, OES1X .
  • HyperView supports the following data block names for PARAM, POST, -2:
  • OQG1, BOUGV1, OUGV1, OES1, OEF1, OSTR1, ONRGY1, OES1X.
  • HyperView supports the following element types for stress and strain data types:
    CQUAD (33), CQUADR (82), CTETRA (39), CTRIAR(70) CQUAD8 (64), CHEXA (67), CPENTA (68), CTRIA3 (74)
    CTRIA6 (75), CQUAD4(144), CTRIAX6 (53)
    For corner stress and strain, following element types are supported:
    CQUAD8 (64), CTRIA6 (75), CQUAD4(144), CTETRA (39), CHEXA (67), CPENTA (68)
  • HyperView supports the following element types for force data type:
    CROD(1), CONROD(10), CBEAM(2), CELAS1(11), CELAS2(12), CGAP(38), CBAR(34), CQUAD4(33), CTRIA3(74),
    CQUAD(64), CQUADR(82), CTRIA6(75), CTRIAR(70), CQUAD4(144)
  • For modal frequency response problems (sol 103), the simulation name is Mode # f #Hz.
  • HyperView supports the following data block names for geometry:
    GEOM1, GEOM1S, GEOM2, GEOM2S
    HEX8(208), HEX20(220), PENTA6(206), PENTA15(215), TETRA4(204),
    TETRA10(210), QUAD4(104), TRIA3(103), QUAD8(108), TRIA6(106),BAR(60),
    ROD(61)
  • All tensor results (2D and 3D) should be viewed in the Element Result System
  • To extract only a selected set of results, use the external translator HvTrans to create an h3d file.
Reading Nastran Model and Result Files
Functionality HyperView – Animation Window
Reads model file directly DAT, NAS, BDF, OP2, XDB
Reads results file directly OP2, XDB
Reads translated results PCH (hmnast: HMRES and H3D)
OP2 (hmnast02:HMRES and H3D)
Nastran Results Form for OP2 and XDB
Nastran centroidal results Yes
Nastran corner results Yes
Thickness contour Yes
Coordinate Systems
Transforms results to other system type in application Yes
Transform any tensor to vector results Yes
