Interfacing with LS-DYNA
Overview of how the HyperView applications interface with the LS-DYNA solver.
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data. If more than one reader claims to support the selected file format, a dialog listing those readers is displayed. From this dialog, you can select the preferred reader.
To extract only a selected set of results, use the external translator HvTrans to create an H3D file.
HyperView can read zipped d3plot files of LS-DYNA using FEMZIP libraries v11.00 or older.
Solver Interface Support
HyperView supports result files created from the LS-DYNA solver using the .d3plot file format.
HyperView can read LS-DYNA eigenvalue analyses (.d3eigv) files.
