HyperView LS-DYNA Results Reader
Supported Results
Data Type Name Result Type Data Type Notes
Displacement NODE VECTOR
Velocity NODE VECTOR
Acceleration NODE VECTOR
Temperature NODE SCALAR
Energy Results NODE SCALAR Supported energy results include internal energy, hourglass energy.
Time step related results NODE SCALAR Supported results include time step size, mass scaling.
CFD Data NODE SCALAR Supported CFD types include pressure, vorticity (x, y, z, and resultant), entropy, helicity, stream function, enthalpy, density, turbulent kinetic energy, and dissipation.
Particle Data NODE/PARTICLE VECTOR/SCALAR Supported particle results include displacement, velocity, spin energy, translational energy, radius, leakage, and gas ID.
Residual Forces and Moments NODE VECTOR
Normal resultant force ELEMENT (1D, 2D) VECTOR
Shear resultant force ELEMENT (1D, 2D) VECTOR
Bending Moment ELEMENT (1D, 2D) VECTOR
Stress ELEMENT (1D, 2D, 3D) TENSOR3-D Thick shell support is for the mid-surface only.
Strain ELEMENT (1D, 2D, 3D) TENSOR3-D Thick shell support is for the inner surface only.
Plastic Strain ELEMENT (1D, 2D, 3D) TENSOR3-D Thick shell not supported.
Thermal Strain ELEMENT (1D, 2D, 3D) TENSOR3-D Thick shell not supported.
Effective plastic strain ELEMENT (1D, 2D, 3D) SCALAR Thick shell support is for the mid-surface only.
Pressure ELEMENT (1D, 2D, 3D) SCALAR Thick shell support is for the mid-surface only.
Thickness ELEMENT (2D) SCALAR
Percent thinning ELEMENT (2D) SCALAR
Interface force in global direction NODE VECTOR Supported from INTFORC file
Interface force - Normal NODE SCALAR Supported from INTFORC file
Interface force - Surface NODE SCALAR Supported from INTFORC file
Contact Gap NODE SCALAR Supported from INTFORC file
Interface shear stress ELEMENT SCALAR Supported from INTFORC file, includes shear stress in r and s direction
Interface pressure - Normal ELEMENT SCALAR Supported from INTFORC file
Interface force-segment ELEMENT VECTOR Supported from INTFORC file (For Fluid structure interaction)
Interface pressure-segment ELEMENT SCALAR Supported from INTFORC file(For Fluid structure interaction)
Peak Pressure ELEMENT SCALAR Supported from INTFORC file
Time to peak ELEMENT SCALAR Supported from INTFORC file
Surface energy density ELEMENT SCALAR Supported from INTFORC file
Note:
  • HyperView supports LS-DYNA version up to R11.1
  • HyperView supports implicit results
  • You can request specific information in the LS-DYNA run to output results, such as beam and strain, in HyperView
  • Corner data results (solids with multiple integration points) are supported
