Contour Panel LS-DYNA Result Types and Component Options
In the Contour panel, select a Result type and a corresponding component type to calculate contours with.
The list of available component types vary based on the selected Result type.
Result Type Component Types
Displacement (v) Mag
X
Y
Z
Acceleration (v) Mag
X
Y
Z
Velocity (v) Mag
X
Y
Z
Strain(t) vonMises
SignedVonMises
P1 (major)
P2 (mid)
P3 (minor)
In-plane P1 (major)
In-plane P2 (minor)
MaxShear
XX
YY
ZZ
XY
YZ
ZX
Stress (t) vonMises
SignedVonMises
P1 (major)
P2 (mid)
P3 (minor)
In-plane P1 (major)
In-plane P2 (minor)
MaxShear
Intensity
Pressure
XX
YY
ZZ
XY
YZ
ZX
ALE Result (s) Fluid Density
Volume fraction of Fluid 1
Volume fraction of Fluid 2
Volume fraction of Fluid 3
Volume fraction of Fluid 4
Dominant Volume fraction
Mass fraction of Fluid 1
Mass fraction of Fluid 2
Mass fraction of Fluid 3
Mass fraction of Fluid 4
Effective plastic strain (s) Scalar value
Extra Solid History (s) Var 1
Var 2
Var 3
Var 4
Var 5
Var 6
Var 7
Var 8
Var 9
Var 10
