mat196 (single row)
Restriction: Only available in LS-DYNA.
This realization creates a single row of BEAM elements for the body.
Note: Use the init_dyna_mat196.ini config file to set the default attributes for the created MATL196 material.
This realization uses the prop_dyna_matnum_seamarea.tcl post script and the weld_config.ini and init_dyna_mat196.ini config file.
