Keyboard Shortcuts & Mouse Controls
Selection
| To do this | Press |
| Select multiple rakes | Press Shift or Ctrl + Left Mouse Click |
| Select all rakes | Press the Ctrl + A |
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
Create your own user defined coordinate systems or select result coordinate systems.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
HyperView offers CFD post-processing capabilities for a large class of industrial applications.
Use the Streamlines tool to generate streamlines using any available nodal or elemental vector field (typically a velocity field).
Use the Tracking tool to track any entity during animation.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
From the Preferences menu, you can access the Options dialog.
