Apply a Contour to a Streamline
  1. From the Streamlines panel, follow the steps to create a Line, Area, or Plane rake/streamline.
  2. From the View Controls toolbar, click .
  3. Select a result type from the Result type drop-down menu.
  4. Click Apply.
    The contour is applied to the streamline.
    Restriction: HyperView supports streamline contouring for nodal results only (elemental results are currently not supported).
