View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
From the Preferences menu, you can access the Options dialog.
Display options are set in the Options dialog.
Set general application options such as showing the splash screen or the getting started screen at startup, showing icon labels, whether to scale the user interface, and picking a theme color.
Set display options such as background color, foreground color, and mesh lines.
Set element mark options and general visualization options.
Set various general performance options, as well as control the Display Acceleration Block (DAB).
Set light sources for illuminating graphics. Lighting settings control the location, direction and intensity (high/low) of the specular lighting.
Set and customize mouse controls.
