Dynamically Change the Tumble Axis
Drag the pointer around the window.
Tumble speed is determined by the distance of the cursor from the center point. The greater the distance from the pointer to the center point, the faster the graphic tumbles. The axis of rotation is the line passing through the center point, perpendicular to the line created by the center point and the current mouse location, within the plane of the screen.
