Draw a Window and Select Entities on a Model
  1. Create the window by adding window points to the screen with your mouse cursor.
  2. To change the size and shape of the window, pick a point with your mouse cursor and drag it until the desired shape is achieved.
  3. Click inside the window to select all the interior entities.
    The entities are highlighted.
  4. Click outside the window to select all the exterior entities.
  5. To delete a point from a window, with the mouse cursor, pick the point that you want deleted.
    The point is removed from the window.
    Note: Depending on your mouse control settings, the mouse button and additional controls set to create a window and select entities from the screen will vary.
