Delete a Layer Filter
  1. Select a filter from the list.
  2. Delete the filter using one of the following methods.
    • Click Delete (located at the bottom of the panel).
    • Press the Delete key on the keyboard.
    The selected filter is removed from the list.
    Note: If an active filter which is used in any of the plots (contour/vector/tensor/iso) is deleted, or its definition is modified by adding or removing layers, you will need to reapply the relevant plot (contour, vector, tensor, or iso plot) to reflect the state of the updated filter. In the case of deleting the active filter, the panels will reset the state of the filters to None, however the plot will need to be reapplied.
