Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add
the currently active contour result to an internal cache.
The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be
bound by same feature angle or face.
The fatigue manager allows you to write stress and strain results from a finite element analysis to an external file that
can be used to set up a fatigue analysis.
The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
The Value filter available in the Contour panel allows you to specify threshold
criteria for processing results only in a specific range.
The Value filter discards any values not meeting the specified
criteria. There are three possible modes to specify a criteria: greater than or equal to (>=),
less than or equal to (<=), or a Range. The results will be displayed on entities (like
nodes, elements, or systems) only when the value criteria is met. By default, no filter is
applied (None). The Value filter is similar to that of an iso surface when processing results,
with the difference being that no result is shown for the entities that do not meet the
criteria (instead of removing those entities from display). The Value filter can be a useful
tool for isolating the 'hotspot' areas. Using this filter along with the Count aggregation
mode, allows you to count the number of layers meeting a certain criteria (for example,
counting the number of plies exceeding a failure index). Figure 1. Contour Panel with Value filter highlighted
The Value filter options (located in the middle of the panel) include:
Mode
Select an option from the drop-down menu:
None (*default setting)
<= (less than or equal to)
>= (greater than or equal to)
Range
Value
Use the field(s) to specify a numerical value or range of values.
Any entities (nodes/elements/parts/systems) that have values outside of the
filter parameters will be displayed as gray in the graphics area. Figure 2.
The Value filter options can be used in conjunction with the Count and Layer
filter, in order to determine which layers/plies are failing or exceeding certain threshold
criteria.
The tables below illustrate how the various Value filter and Layer filter
options work together: Figure 3.
All layers are included in the count and other calculations (Max, Min,
etc.).
Figure 4.
Only the layers which are less than or equal to 0.4 (the Value filter setting) are
included in the count and other calculations (Max, Min, etc.).
Figure 5.
Only the layers which are greater than or equal to 0.4 (the Value filter setting) are
Figure 6.
Only layers 1, 3, and 5 (selected using the Layer filter) which are greater than or
equal to 0.4 (the Value filter setting) and are included in the count and other calculations
(Max, Min, etc.).
