Select a Projection Rule
  1. From the View Controls toolbar, click .
  2. From the Contour panel, click the Projection Rule button.
    The Projection Rule dialog is displayed.
  3. Select the primary and secondary axes from either the global or user-defined system (selected for Resolved in).
    When the primary axis is perpendicular to the shell plane, the secondary axis is used.
    See the Projection Rule topic for additional information.
