Create Plot Style
  1. From the View Controls toolbar, click .
  2. From the Contour panel, click the Create Plot Style button.
    The Create/Update Contour Plot Style dialog opens, which allows you to create or update a result plot style based on the current settings of the contour.
    Note: A contour plot needs to be current in order to create a new style or modify an existing one.
    All the settings of the contour plot (corner data options, averaging, resolved in systems, default data type/components, display options, legend, etc.) are captured in the named style.
