Translate a Graphical Object Using the Transform Tab
During transformations, you can select multiple objects and transform them simultaneously.
  1. From the Add Object panel, select an object from the Add Objects list.
    Tip: You can also click on the object in the modeling window.
  2. Click the Transform tab.
  3. Under Translate, enter offset values for X, Y, and Z.
  4. Activate the X, Y, and Z check boxes to indicate the desired axes of translation (if necessary).
  5. Press the + or - buttons to translate the object along the offset vector.
