Export
The Tools menu Export option allows you to access sub-menu options and dialogs for iso surface, plot styles, sets, and views.
Export Plot Styles
The Export Plot Styles feature allows you to export your own plot styles and make them your default. The current plot styles will be written out in XML format to a file you define. You can use these styles as your own default by changing the DefaultPlotStyles line in your preference file. Set the path and file name to your plot styles file.
  1. From the Tools menu, select Export > Plot Styles.
    The Export Styles dialog is displayed.
  2. From the Save in file browser, select the directory to which you want to save your file.
  3. Enter a file name and click Save.
    This file can then be imported using the Import Plot Styles option.
Export Sets
The Export Sets option allows you to export HyperView group definition files or Patran session files.
  1. From the Tools menu, select Export > Sets.
    You are automatically taken to the Set panel, and the Export Sets dialog is displayed.
    Note: You can also access the Export Sets dialog by clicking Export in the Set panel.
  2. From the Select format drop-down menu, select a file type (HyperView group definition file or Patran session file).
  3. From the File name file browser, select the directory and name to which you want to save your file.
  4. Click Save.
  5. Optional: Activate the Export selected sets option to export only selected sets in the panel or in the browser (if desired).
  6. Click OK to close the dialog.
    You can now import this file by clicking Import in the Set panel.
Export Views
The Export Views option allows you to export your current saved views. The views will be written out in .txt format to a file that you define.
  1. From the Tools menu, select Export > Views.
    The Export Views dialog is displayed.
    This file can then be imported using the Import Views option.
Export an Iso Surface
The Export Iso Surface feature allows you to export the iso surface volume created from solid elements in the STL format. This file can be read into HyperMesh or a CAD tool for design review.
  1. From the Tools menu, select Export > Iso Surface.
    The Export Iso Surface dialog is displayed.
  2. From the Select format drop-down menu, select STL.
  4. Click Save.
  5. Click OK to close the dialog.
    You can now open this file in HyperMesh (or another pre-processor), or a CAD tool for design review.
