Set Wizard Paths
The Set Wizard Path dialog allows you to set the directories in which the several files are stored.
List of files set in the dialog:
  • Assembly wizard file
  • Task wizard file
  • MDL standard include file
  • Wizard library directory
  • Report log file
See the Set Wizard Paths Dialog topic for additional information.
