Assembly Wizard Dialog
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard, located on the Model menu. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
Figure 1. Assembly Wizard Dialog
Next
Moves to the next panel.
Back
Returns to the previous panel for review or edit.
Cancel
Closes the Assembly Wizard.
Reset Selection
Resets the assembly wizard.
Message Log...
Displays the message log at the bottom of the dialog.
Clear
Clears the message log.
Note: This button is only activate if the message log is displayed.
Model Type
Driveline Configuration
Figure 3.
Primary Systems
Figure 4.
Steering Subsystems
Figure 5.
Springs, Dampers, and Stabars
Figure 6.
Jounce/Rebound Bumpers
Figure 7.
Label and Varname Specifications
Figure 8.
Once you have made your selections, the Assembly Wizard retrieves the systems from the libraries and connects them in a hierarchical structure.
The attachments specified during the assembly process can be modified using the Attachment Wizard dialog.
Assemble a Model
  1. From the MotionView Model menu, select Assembly Wizard.
    The Assembly Wizard dialog is displayed.
  2. Move through the dialogs using Next and Back, selecting the model type, properties, and attachments.
  3. Click Finish.
    The completed model is displayed in the graphic window.
