Browser Context Menu Options
Run Event | Runs the event (exports XML, ADF and submits the solver input file to MotionSolve). |
Run All | Runs all of the full vehicle events added in the model. |
Edit Event | Brings up the event setting dialog/Event Editor. |
Build Event | Exports the solver input file and ADF file to the path provided in the Event Editor dialog. |
Edit XML | Opens the XML in text editor. |
Edit ADF | Opens the ADF text editor. |
Run XML | Submits the solver input file (if generated) to MotionSolve. |
