Constant Radius
A Constant radius event simulates a vehicle driving in a circular path, typically with increasing speed. The event predicts the vehicles roll and understeer characteristics with increasing lateral acceleration.
The Constant radius event maintains a constant turn radius and varies the vehicle velocity to produce increasing amounts of lateral acceleration. Steering and torque controllers maintain the path and the speed of the vehicle through the event. A plot template is available to plot the results.
References
ISO +4138-2004 - Passenger cars — Steady-state circular driving behavior — Open-loop test methods.
Event Inputs
Use event inputs to define the constant radius parameter and to select the road that the event is run on.
Event Parameters
Parameter Description
Units Length unit selection (Model, m, ft).
Velocity unit selection (Model, m/s, km/h, mph).
Acceleration unit selection (Model, m/s2, g’s).
Radius The radius of the circle that the vehicle CG will follow during the constant radius portion of the event.
Initial straight Vehicle is driven straight this distance and corners in a given radius to attain steady state.
Initial velocity Initial vehicle velocity.
Final velocity Final velocity desired in the simulation.
Initial lateral acceleration Estimated initial lateral acceleration, calculated using the initial speed and the turn radius.
Final lateral acceleration Estimated final lateral acceleration, calculated using the initial speed and the turn radius.
Turn direction Direction the vehicle turns during the event (as seen by the driver).
Transient time Time duration for which vehicle accelerates/decelerates after achieving steady state.
Look ahead time Look ahead time, used by the Driver feedforward steering model.
Prediction step size Maximum step size, used by the Driver feedforward steering model.
Print interval Time interval of data output to the plot file (.plt) and graphics file (.h3d).
Road Parameters
Use the road parameters to select the road that the vehicle drives on for the event. You can choose to use a flat road, a road data file you select from the event editor, or the road data files selected by tires. The table below describes the parameters in detail.
Road Selection This option menu determines the road selected for the event. There are three choices:
  • Flat Road - Use a flat, smooth road for the event. No road file is needed. Use the road settings to control the road graphics and road mu.
  • From Event - Select a road file from the event road file field. All tires in the model use this road file when running the event.
  • From Tires - For each tire in the model, use the road file selected for that tire in the AutoTire panel. This allows you to use different road files for different tires.
Road Selection = Flat Road
When the road Selection is Flat Road, then the event is run on automatically generated flat road data file.
Mu (Friction Scale) Enter a value greater than or equal to zero that scales the tire-road surface friction. Note the tire-road surface friction is defined in the tire properties. So, if you enter a 0.5 here and the tire-road friction coefficient is 0.8, the effective coefficient of friction is 0.5*0.8 = 0.4.
Show Graphics Check this box to create graphics for the flat road. Note the graphics are created when you click the Apply or Run button on the event editor.
Graphic Settings Push this button to display a dialog that controls the flat road graphics, to learn more about the controls see the Road Settings section below.
Road Selection = From Event
Road File When the Road Selection option is From Event, use the road file field to select the road file for the event.
Road Selection = From AutoTires
When the Road Selection is From AutoTires, then each tire runs on the road property file specified for it in the AutoTire panel. This allows the use of different road files for different tires, for example, one road for the right tires and another for the left tires to provide different vertical disturbance.
Driver
Use the Driver tab to set Proportional, Integral and Derivative (PID) gains and output signal filtering. The PID controllers employed by the Driver depend on the vehicle.
PID Controllers
The Lean PID and Lateral Error PID controllers only apply to leaning vehicles (for example, motorcycles and scooters), while the Longitudinal PID applies to both leaning and non-leaning (for example, cars and trucks) vehicles. Hence the user interface only displays fields for the Lean and Lateral Error PID gains for leaning vehicles.
Lean PID
For leaning vehicles, the Lean PID takes as input a demand lean angle and outputs front fork (steering) angle. For open loop events the lean angle demand is a function of time. For closed loop path following events the demand lean angle is computed based on the vehicle speed and the path curvature with a correction for lateral path error. For more information see the Lean Angle Controller - Two-wheelers topic and also the Gain Tuning for Leaning Two and Three Wheeler Vehicles topic.
Lateral Error PID
For leaning vehicles, the Lateral Error PID takes as input the predicted lateral path error and outputs an increment to the demanded lean angle. The lateral error is computed by predicting the vehicle’s lateral position relative to the path by the look ahead time in the future. The Lateral Error PID acts to lean the vehicle toward the path. For more information see the Lean Angle Controller - Two-wheelers topic.
Longitudinal PID
You can add the longitudinal PID controller to any vehicle to correct for disturbances not accounted for in the feedforward section of the longitudinal controller and to remove steady-state error. The longitudinal PID takes as input velocity error and outputs throttle.
For more information see the Altair Driver Mathematical Methods topic.
Signal Settings
Use the signal settings to set minimum, maximum, and initial values for Steering, Throttle, Brake, Gear and Clutch signals output by the driver. The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Steering values have units of radians and smoothing frequency has units of Hz (cycles/second). Other values have no units.
Road Settings
The Road Settings dialog controls the display of the rectangular road graphics.
When a Flat Event is selected for the road and the Display Graphics option is checked, the event generates rectangular graphics for the road. Clicking the Graphic Settings button displays the Road Settings dialog which gives you control over the road graphics.
Figure 3. Road Setting Dialog
Grid Parameters
Use the parameters to control the visibility and size of the flat road graphics as described in the table below.
View Grid Road The View Grid Road check box toggles the road grid graphics on and off.
View Event Path The View Event Path check box toggles the event path graphics on and off.
Note: This check box is disabled for open loop events without a path.
Event Based Grid Check the Event Based Grid option to automatically size the length and width of the road graphics based on the event parameters, like the initial straight and radius for the constant radius event. Remove the check from the Event Based Grid option to input the size of the road graphics.
Grid Square Size Enter a positive value in model units giving the length and width of squares in the road graphics.
Grid Length Enter a positive value in model units giving the length of the road graphics.
Grid Width Enter a positive value in model units giving the width of the road graphics.
Grid X Offset Enter a value in model units giving the distance to offset the road graphics in the longitudinal direction.
Grid Y Offset Enter a value in model units giving the distance to offset the road graphics in the lateral direction.
Grid Color
To change the color of the road grid squares or the event path, check the respective check box and then pick the desired color from the palette.
Note: The Event Path check box is disabled for open loop events without a path.
