Troubleshooting Driver Modeling
Below are some recommendations for using Altair Driver:
Symptom
The driver simulation fails immediately.
Remedy
Verify that the vehicle position is consistent with the specified path. The path points need to be close to the vehicle at design position.
Symptom
The driver seems to turn the steering wheel angle counter-intuitively and it does not follow the prescribed path. The simulation fails.
Remedy
This is probably caused by positive feedback. This can be fixed by reversing the sign of the steering wheel angle signal or the steering rack ratio.
Symptom
The driver follows the path, but it is too sluggish. The simulation fails.
Remedy
This could be caused by a preview time that is too long for the maneuver and the vehicle speed, especially if the steering signal seems to start responding too soon.
Symptom
The driver follows the path, but its actions are too sudden and the steering wheel angle signal is too jumpy.
Remedy
This could be caused by a preview time too short for the maneuver and the vehicle speed, especially if the steering signal seems to start responding too late.
