Assembly Wizard
  1. Model type – “Full vehicle with driver”.
  2. Primary systems for full vehicle with Altair driver model.
    1. Powertrain - The powertrain system available in the library are the following:
      Manual transmission
      IC Engine Friction Clutch Powertrain.
      Linear Torque Map Powertrain
      Engine that applies torque directly proportional to driver throttle output.
  3. Select a driveline system.
    1. Disk brakes: Apply braking torque on the wheel joint proportional to the driver brake output.
      Figure 3.
