Connecting an AutoTire
  1. From the Connectivity tab, select the wheel body on which the tire forces act.
    • Click on the Hub Body collector and select a body from the modeling window.
    • Double click Hub Body and select the required body from the model.
  2. Similarly, select a point corresponding to the wheel center by clicking the Wheel Center input collector.
  3. Double click the Tire Marker collector and select the required marker from the model.
  4. Similarly, select a marker for the Road Marker.
    The tire model is displayed in the modeling window.
