Copy and Paste a Datum Line
- From modeling window, select a datum line.
- Right-click and select Copy.
- Go to the page where you want to paste a copy of the datum line and click on a plot.
From the same menu, select Paste.
The datum line is pasted on top of the original with the same name. It is also added to the list of datum lines in the Plot Browser.
Use one of the following methods to edit the new datum line :
- Right-click and select Edit. Use the Entity Editor to edit the datum line.
- Double-click on a datum line to display the Entity Editor.
- From the Plot Browser, click Datum Lines, , to view and edit the datum line properties.
See Edit a Datum Line for more information.
