pltIBuildPlotsCtrl SetYDatatype
Sets the value for the Y data type.
pltIBuildPlotsCtrl_handle SetYDatatype dtype
HyperWorks Tcl Modify
This command sets the value for the Y data type variable from within the Y data type list.
Note: The command must be called after to draw the plot with these changes.
dtype
A string with the value of the Y data type that you want.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetYDatatype “Angular Acceleration”;
Keywords
HyperWorks
Tcl
Build Plots
Modify
