Adds a Macro.
Adds a statistics template.
Copies a Macro.
Gets the build plots control handle.
Finds the default dynamic range.
Gets the export control handle.
Gets the macro handle.
Finds the number of objects on the clipboard.
Finds the number of macros.
Finds the total number of statistics templates.
Returns the preload maximum file size for post-processing a large number of pedestrian results.
Gets a specific statistics template handle.
Determines the state of the Use Even Cycles option.
Pastes a macro.
Recalculates all data.
Registers and saves an export template based on an exported file.
Removes a macro.
Removes a statistics template.
Sets the default dynamic range.
Sets the preload maximum file size for post-processing a large number of pedestrian result files.
Sets the state of the Use Even Cycles option.
Undoes a macro.
ON THIS PAGE
ON THIS PAGE
