pltIBuildPlotsCtrl SetComponentFilter
Sets the Y component filter.
pltIBuildPlotsCtrl_handle SeComponentFilter component_filter
HyperWorks Tcl Modify
This command sets the value in the Y component filter. The filter removes Y components from the Y component list that do not match the filter value.
component_filter
The string that you want to use as a filter. All Y components that do not have this string within it will be removed from the Y components list.
Examples
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SeComponentFilter “comp.”;
Keywords
HyperWorks
Tcl
Build Plots
Modify
