hwIXMLFile IsAttribute
Finds if the node or folder is an attribute.
hwIXMLFile_handle IsAttribute ident
HyperWorks Tcl Query
This command finds if the node or folder is an attribute. An attribute is a node, a name or value; NOT a folder of any kind. An attribute does not have levels below it. If the input is an attribute, true is returned. Otherwise, false is returned.
ident
The variable name (Templex statement) of the node or folder.
hwi GetSessionHandle sess;
sess GetXMLFileHandle XML “c:/Documents and Settings/user/My Documents/hwsettings.xml”;
XML IsAttribute section.section.entry.5.value;
Error
Returns success (a true or false value) or an error code.
Keywords
HyperWorks
Tcl
XML
Query
