hwIWindow SetHTMLOutputType
Sets the window caption used when exporting to HTML.
hwIWindow_handle SetHTMLOutputType type
HyperWorks Tcl Modify
This parameter is used during HTML export. It indicates the type of the object created when you click on this window in the HTML report. Not all options are supported by every client.
type
The output type of the window. Can be "avi", "jpeg", "h3d", "bitmap", or "html", depending on the client type.
To set the HTML output type of window 1 on page 1 to h3d:
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage GetWindowHandle myWindow 1
myWindow SetHTMLOutputType h3d
Success (0) or an error code (see below).
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
HW_InvalidArgs - The value of argument type is invalid for the window’s client type.
