hwITemplex GetNumberOfFunctionParameters
Determines the number of required parameters for a specified math function.
hwITemplex_handle GetNumberOfFunctionParameters funcname
HyperWorks Tcl Query
funcname
The function for which the number of required parameters is desired.
Returns the number of required parameters for the given function. -1 denotes an error.
To determine the number of required parameters for the ‘frfmag’ math function:
mySessionName GetProjectHandle myProjectName
myProjectName GetTemplexHandle myTemplexName
myTemplexName GetNumberOfFunctionParameters frfmag
None.
