hwIReportTemplate SetParameterValue
Sets the parameter of a report.
hwIReportTemplate_handle SetParameterValue name, value
HyperWorks Tcl Modify
This command sets the parameter value (the input area in the GUI for parameter).
name
The name of the parameter that you want to set.
value
The value or filepath that you want to set in the parameter.
hwi GetSessionHandle sess;
sess GetReportTemplateHandle rep 1;
rep SetParameterValue dat_file
c:/demos/mv_hv_hg/reports/text_summary/sdf.dat;
Error
Keywords
HyperWorks
Tcl
Report Template
Template
Modify
