hwIProject CutPage
Cuts a page.
hwIProject_handle CutPage page, append
HyperWorks Tcl Modify
This command cuts a page out of the project based on the page number you input.
page
The page number that you want to cut out.
append
True or False
True
Indicates that the cut is added to a memory.
False
Indicates that the cut is not added to memory.
Multiple cuts can be made and pasted at the same time, rather than cutting and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj CutPage 1 true
Error
Keywords
HyperWorks
Tcl
Modify
