hwIMessageLog SetMessageLimit
Changes the maximum number of messages that can be stored in the Message Log.
hwIMessageLog_handle SetMessageLimit messageLimit
HyperWorks Tcl Query
This command sets the maximum number of messages that can be stored in the Message Log.
messageLimit
An integer value specifying the maximum number of messages that can be stored in the message log.
  • If the new limit is less than the current limit, then the oldest messages in the log will be lost.
  • If the new limit is greater than the current limit, there is no effect on the contents of the log.
In both cases, the Message Log display is refreshed.
hwi GetSessionHandle sess;
sess GetMessageLogHandle msgLog;
msgLog SetMessageLimit 2048
Error
Keywords
HyperWorks
Tcl
Message Log
Modify
