hwIJPGExportOptions SetQuality
Sets the quality used when exporting JPG files.
hwIJPGExportOptions_handle SetQuality quality
HyperWorks Tcl Modify
This parameter is used when exporting JPG files from any client during HTML export.
quality
The quality to be used when exporting JPG files. This must be between 0 and 100 (exclusive).
To set the current quality used when exporting JPG files:
mySessionName GetJPGExportOptionsHandle myJpgOptions
myJpgOptions SetQuality 90
Success (0) or an error code (see below).
3 = HW_InvalidHandle
The handle used to invoke the method is no longer valid.
4 = HW_InvalidArgs
The value of the argument quality is not in the range listed above.
