hwIAnimator SetUseBitmap
Sets the current animator's use bitmap flag.
hwIAnimator_handle SetUseBitmap usebitmap
HyperView Tcl Modify
This command sets the current animator's use bitmap flag.
Note: This flag is used to speed up animation of large models by saving bitmap images for each frame, then flipping through them instead of recalculating each frame.
usebitmap
The use bitmap state: either true or false.
Error
Returns 0 if successful, otherwise an error code.
