hwIAMFExportOptions GetSize
Gets the relative size (percent) used when exporting AMF files.
hwIAMFExportOptions_handle GetSize
HyperView Tcl Query
This command retrieves the relative size (percent) used when exporting AMF files. This is an integer value, with possible values including 100, 75, 50, or 33.
Note: This parameter is used when exporting AMF files from either the video or animation clients during video capture.
To determine the current size used when exporting AMF files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions GetSize
Error
Returns the relative size (in percent) used when exporting AMF files, otherwise 0 if an error occurs.
