hwI3DViewCtrl SetOrientation
Sets the orientation of the plot.
hwI3DViewControl_handle SetOrientation str
HyperWorks Tcl Modify
This command sets the orientation (view) of the plot to your request.
str
Input one of the following strings to change the orientation: “left”, “right”, “top”, “bottom”, “front”, “back”, “reverse” or “iso”.
Each string represents an orientation.
left
Represents a view of the left side of the 3D plot.
right
Represents a view of the right side of the 3D plot.
top
Represents the top side of the 3D plot.
bottom
Represents the bottom side of the 3D plot.
Each of the above views only shows that particular side, creating a 2D view.
"iso"
Represents a view of the entire plot, showing the x, y, and z axes in 3D.
"reverse"
Sets the plot to the opposite view of th current orientation.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc
vc SetOrientation “reverse”
Error
Returns success (0) or an error message.
Keywords
HyperWorks
3D plot
Tcl
Modify
