hgtrans control GetLabelAliasPattern
Gets the pattern associated with a previously defined alias.
hgtrans control GetLabelAliasPattern subcase, datatype, level, index
HyperGraphTrans Tcl Get
This command gets the pattern associated with a previously defined aliasing rule.
subcase
The name of the subcase in which to apply the rule.
datatype
The name of the datatype in which to apply the rule. (Does not apply if the level is “subcase”.)
level
The level of labels at which to apply the rule.
datatype
request
component
index
The index of the rule. One-based. It must be an integer greater than zero.
Add a rule to change the word “head” in all request names to its Spanish equivalent “cabeza” and then read it back. Assumes that this is the first rule added.
hgtrans control AddLabelAliasRule “head” “cabeza” “Subcase 1” “Displacement” request
hgtrans control GetLabelAliasPattern “Subcase 1” “Displacement” request 1
Returns an empty string if no matching rule exists.
Keywords
get channel alias
