hgtrans control GetEnd
Gets the last data point index to be translated.
HyperGraphTrans Tcl Query
This command gets the index of the last data point to be translated in each channel. The index is one-based and defaults to negative one (the end).
Sets hgtrans to translate only the first hundred data points, and then verifies it.
hgtrans control SetEnd 100
If the starting index is higher than the last data value index present, no data will be translated.
Keywords
get end
